IR Remotecontrol
Im wanting to use my "Board of education Full Kit" and "Understanding Signals" to create a 2 button remote control to turn a tv on/off and mute the tv is a dynex.
I have found alot of info on decoding a sony remote but nothing on decoding any other brands. also even with the sony all i have been able to find is info on decoding the signal but nothing on cloning the signal and sending it from stamp.
Please help as i am new to this
And only Sony (and Phillips) has published what they use. So, the first thing to do is find out what the signal is.
I've done this using a USB based logic analyzer, connected to an IR-decoder chip. You can get the IR-decoder chip at Radio Shack or Parallax, it's a three-terminal device which is looking for RF-light blinking at a 38.5 KHz rate. When it sees this, its normally high output goes low as long as it's seeing it.
So what you do is hook up the IR-decoder chip (I think it's shown in "Understanding Signals") and put a logic analyzer on the data pin. Then aim your remote at the IR-decoder and press the 'off' button. The logic analyzer will then show you what the encoding is -- some amount of time lit for a '1', some amount lit for a 'zero', and some string of '1's and '0's to encode the key-press.
