RE: Propeller EEPROM Problem — Parallax Forums
schwiegjcschwiegjc Posts: 41
edited 2009-10-20 15:02 in Propeller 1
When I try to load a program into EEPROM, I get the following error "EEPROM verify error on COM9" message. The program seems to work fine when load into RAM.
    edited 2009-10-20 04:43
    You may have a bad EEPROM or a bad solder joint on one of the EEPROM pins. Have you tried loading other programs? If a program is too large for the EEPROM, you could get that message. What EEPROM are you using?
  • schwiegjcschwiegjc Posts: 41
    edited 2009-10-20 14:32
    I have the Propeller USB Board. The program seems to work when I just load into RAM, but when I try to loaded it into EEPROM it gives me an error. I loaded the program into the demo propellar board and did loaded fine. I will look at the solder connections first. Thank you
    Try calling Parallax tech support. You may have a defective board.
