reading voltage with prop
a friend came up to me the other day and was wondering about an airplane we are building, he was wondering if i would be able to build a circuit to monitor the voltage of the batteries. since this is a test plane and the prop is already on board for relaying gyro/accelerometer info back to the display, i was wondering if there was a simple circuit i could use to measure when the batteries got to 6.3 volts and then to 6.0, since we are using a two cell lipo that is not supposed to go below 6 volts. the 6.3 could be changed and probably will depending on the actual strain of the electronics and motor on the battery. basically we are building a plane monitor that transmits stupid info to a display...any help is greatly appreciated.
edit: would a simple adc work and then just do some testing to figure out the voltage to adc values
