Propeller servo controller
This is a framented thought, but do the level shifters allow rctime , or pwm or serial communications, or are there better solutions to interfacing the prop chip to higher voltage levels
if it does work, then imagine a small board ie , The Propeller servo controller replacing the basic stamp on a boe bot
just wondering bc i've looked at the spec of the level shifter, and i'm not sure if it would work for things like ping, photoresistors, ir detectors... that are used on the boe bot
