pull up/down on pin 30/31
I know I could test this, but I thought it may be faster to ask.
Could it ever be a problem to have pin 30 or 31 with a pull up or pull down resistor on it? Like a 5K or 10K-ohm?
EDIT: that is, I concerned about it while programming the chip.
April, 2008: when I discovered the answers to all my micro-computational-botherations!
Some of my objects:
MCP3X08/4 ADC Driver - Programmable Schmitt inputs, frequency reading, and more!
Simple Propeller-based Database - Making life easier and more readable for all your EEPROM storage needs.
String Manipulation Library - Don't make strings the bane of the Propeller, bend them to your will!
Post Edited (Bobb Fwed) : 10/19/2009 9:03:26 PM GMT
Some of my objects:
I am trying to connect other components to these pins, but I need some pull resistors (I should be able to arrange my hardware/software so it could accept up or down). During programming does the prop plug drive the pins high and low or is it set to input at some point? Or how does this work?
I also want the pins to be compatible with the propeller loader object.
Some of my objects:
I definitely recommend 4.7K pullups on both pins.
Some of my objects:
