Help with IGBT specs
Hello All
·I am having trouble understanding the specs for the Fuji 2MBI 200N-120 IGBT. I have attached the spec sheet below.
My first ? is: what is the full on voltage. The spec states 20v max but later I see 4.5v min· 7.5v max for the gate voltage. I'm confused.
My second ? is: What is E1 and E2 for?
I couldn't find a typical application schematic for use·as a motor driver.If You have one it would help me a lot.
·I'm very new to IGBTs.This is My first·rodeo with them.
I salvaged·the IGBTs from some old V.F.D.s at work. I looked up the price·$400 ea.
I have 2 600watt/24volt DC motors that I want to control. I feel this would be a breeze for these IGBTs. If I use two per motor I should be
·able to make an H bridge.
Any help will be greatly appreciated.
____Thanks in advance_________________$WMc%______________
The Truth is out there············___$WMc%___···························· BoogerWoods, FL. USA
Post Edited ($WMc%) : 10/18/2009 5:59:46 PM GMT
There are two IGBTs in this device connected in series. E1 is the "emitter" of one and E2 is the "emitter" of the other. You'll need a "high-side driver" for G1 / E1 since these are above ground. Remember that the threshold voltage for G1 is relative to E1 and E1 could be many volts above ground. The high-side drivers reference the switching voltage to the high-side voltage (C1) rather than ground.
Thanks for the reply
I added the rest of the spec sheet data to my first post
I'm still a little confused with E1 and E2
If no voltage has been applied to G1 ,(IGBT off) How would I get a reference voltage from E1 ?
I'm looking at these IGBTs as MOSFETS as far as turning them on and off and I think this is were the confusion comes in.
____Struggling_____________$WMc%_______________
Here's an article on a discrete high-side driver: www.innovatia.com/Design_Center/High-Side%20Drivers.htm
The author references several ICs that combine a high-side and low-side driver. Have a look at them too.
Thats what I was hoping. I have 13.2-13.8V. This helps a lot.
I'll check out the link. I need a lot more study on IGBTs and Hi - Lo side drivers.
________Thanks Again_______________$WMc%____________________studying____
Thanks again for the link.
I see its pretty easy to turn on an IGBT, But it must be turned off as well before another is turned on. (HI-LO drivers)
It all makes since know.
You are the MAN !
