Question about fusing a power supply — Parallax Forums
T ChapT Chap Posts: 4,223
edited 2009-10-20 00:57 in General Discussion
On a product I am building, I have a power supply 120AC to 26VDC unregulated and switching 5 volts. I have seen power supplies short out in the past and smoke, so I was considering some protection against an unlikely event such as this. Would it be a good practice to include a fuse to one side of the transformer main input? Assuming so, how would I determine the value of the fuse? My thoughts are to measure the peak (power up) and average current limits, and use a fuse an amp higher. I am not sure whether fast or slow makes the most sense. The idea is for safety primarily, but I also don't want to be getting calls that the gadget has stopped working and find out the fuse was blown when there was not a real problem, I would assume slow blow is best suited for this concern. Any suggestions appreciated.
  • LeonLeon Posts: 7,620
    edited 2009-10-18 11:32
    Here in the UK fuses like that are mandatory on all equipment. Most suppliers of fuses will have selection guidelines - try Littelfuse.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
  • stamptrolstamptrol Posts: 1,731
    edited 2009-10-18 11:47
    If you must guess, take the VA capacity of the transformer and calculate the full load current ( VA/120, in your case). Then use a slow-blow fuse of about 150% current on the primary (120 volt) side.
    Tom Sisk
    http://www.siskconsult.com
  • edited 2009-10-18 12:41
    Yeara and years ago, I was operating some equipment with six or eight car batteries and the fused melted and "fused" in place and the motor burned out. What causes that and how do you protect against that?
    edited 2009-10-18 14:00
    Use a good quality fuse and holder?
    Leon
    edited 2009-10-18 15:01
    Fuses have a maximum voltage rating and fuse holders have a maximum current rating as well. You have to use a fuse and holder designed to interrupt the voltage and current you're using. A fuse holder with a maximum current rating of 20A may soften or melt and allow the two ends to come in contact if you're trying to run 40A through it. A fuse or fuse holder designed for up to 50V usage may arc over if you try to use it on a 240V circuit.
  • T ChapT Chap Posts: 4,223
    edited 2009-10-18 15:26
    That's every good info guys. Much appreciated.
    On a similar subject, I started giving thought to a device that the Prop could turn off under certain circumstances:
    The enclosure for the boards has a temperature sensor IC, so if something is overheating the enclosure will rather quickly change it's temp, so I could set a temp threshold to a value where the enclosure would never exceed, and if it does then have the Prop turn off the power. On any fault detected by the Prop (i.e. excessive current on the motor driver due to shorted mosfet/motor etc) it can stop the AC also. This is an idea of the extra protection in case of fuse failure. I have no ideas yet on such a device.
  • CounterRotatingPropsCounterRotatingProps Posts: 1,132
    edited 2009-10-19 14:54
    Todd,
    Depending on the design. that might not work as you'd like. An overheating component's heat can be·highly localized at first. A carbon resistor, for example, can fry in place and blow open. Although the heat can be intense enough to "charcoal" the board underneath, the amount actually radiated into the enclosure might not even register on the sensor.
    If you know which components might overheat, you could put the sensors directly on them. Then again - and this might seem obvious - it would be better to stop the problem before it starts: in the design... give yourself enough duty cycle, headroom, load capacity of the components in the first place. Better to spend a bit more on components upfront than to use time, money, and aspirin.
    - H
  • $WMc%$WMc% Posts: 1,884
    About ten years ago
    I hacked a Genie garage door opener to make a gate opener. To make a long story short, Genie used an opto/chopper wheel on the back of the 120vAC motor to detect a drop in motor RPMs signifying an obstruction. This worked really well.It was very fast in detection and immediately reversed the motor.It also detected zero speed on the motor before reversing it. This is important with split single phase motors.(Signal phase reversible motors)
    My point: RPMs are instant , Heat comes with time.
    This is assuming the load is a motor.
    _____I try to stay in the AC_________$WMc%____________________out______
    The Truth is out there············___$WMc%___···························· BoogerWoods, FL. USA
    Post Edited ($WMc%) : 10/20/2009 1:09:12 AM GMT
