Parallax 4x20 Serial LCD (Backlit) Issue
Hello i have a Parallax 4x20 Serial LCD (Backlit) and i have a few questions i have some demo code that parallax provided but i can not get it to work.Also how long can the basic stamp run with this huge lcd and backlight ?
CODE
'·· File...... Serial_LCD_Terminal.BS2
'·· Purpose... Serial LCD Debug Terminal Demo
'·· Author.... (c) Parallax, Inc. -- All Rights Reserved
'·· E-mail.... support@parallax.com
'·· Started...
'·· Updated... 15 JUN 2009
'·· {$STAMP BS2}
'·· {$PBASIC 2.5}
[noparse][[/noparse] Revision History ]
' 06-15-2009:
' Added a 5 mS delay to commands sent via ESC so Clear Screen would work.
[noparse][[/noparse] Program Description ]
' Uses the BASIC Stamp debug terminal to send characters to
' the Serial LCD.
' Typed characters show up automatically on the display of
' the Serial LCD.
' To send a command with a specific value:
'·· * Press [noparse][[/noparse]Esc]"
'·· * Enter the value (0 to 255)
'·· * Press [noparse][[/noparse]Return]
' This second direct command mode enables sending of all the
' command codes, such as display on/off, cursor movement,
' and custom characters. Note that decimal, hexadecimal, and
' even binary input may be used.
[noparse][[/noparse] I/O Definitions ]
TX············· PIN···· 15·············· ' serial output to LCD
[noparse][[/noparse] Constants ]
#SELECT $STAMP
· #CASE BS2, BS2E, BS2PE
··· T2400······ CON···· 396
··· T9600······ CON···· 84
··· T19K2······ CON···· 32
· #CASE BS2SX, BS2P
··· T2400······ CON···· 1021
··· T9600······ CON···· 240
··· T19K2······ CON···· 110
#ENDSELECT
LcdBkSpc······· CON···· $08············ ' move cursor left
LcdRt·········· CON···· $09············ ' move cursor right
LcdLF·········· CON···· $0A············ ' move cursor down 1 line
LcdCls········· CON···· $0C············ ' clear LCD (use PAUSE 5 after)
LcdCR·········· CON···· $0D············ ' move pos 0 of next line
LcdBLon········ CON···· $11············ ' backlight on
LcdBLoff······· CON···· $12············ ' backlight off
LcdOff········· CON···· $15············ ' LCD off
LcdOn1········· CON···· $16············ ' LCD on; cursor off, blink off
LcdOn2········· CON···· $17············ ' LCD on; cursor off, blink on
LcdOn3········· CON···· $18············ ' LCD on; cursor on, blink off
LcdOn4········· CON···· $19············ ' LCD on; cursor on, blink on
LcdLine1······· CON···· $80············ ' move to line 1, column 0
LcdLine2······· CON···· $94············ ' move to line 2, column 0
Esc············ CON···· 27
[noparse][[/noparse] Variables ]
charIn········· VAR···· Byte··········· ' input from user
baud··········· VAR···· Word··········· ' baud rate for Serial LCD
[noparse][[/noparse] Initialization ]
Reset:
· HIGH TX······························ ' setup TX pin for LCD
· PAUSE 100···························· ' allow LCD to intialize
Menu:
· DEBUG CLS,
······· "Parallax Serial LCD", CR,
", CR,
······· CR,
······· "Select LCD baud rate:", CR,
······· "[noparse][[/noparse]1] 2400", CR,
······· "[noparse][[/noparse]2] 9600", CR,
······· "[noparse][[/noparse]3] 19200"
· DEBUGIN charIn
· SELECT charIn························ ' set baud to user selection
··· CASE "1"
····· baud = T2400
··· CASE "2"
····· baud = T9600
··· CASE "3"
····· baud = T19K2
··· CASE ELSE
····· GOTO Menu························ ' selection was invalid
· ENDSELECT
[noparse][[/noparse] Program Code ]
Main:
· SEROUT TX, baud, [noparse][[/noparse]LcdOn3, LcdCls]···· ' cursor on, clear display
· DEBUG CLS,
······· "Just type to send a character to the Serial LCD, or", CR,
······· "To enter a value directly:", CR,
······· "-- Press [noparse][[/noparse]Esc]", CR,
······· "-- Enter the value (0 to 255)", CR,
······· "-- Press [noparse][[/noparse]Enter]"
· DO
··· DEBUG CRSRXY, 0, 6, ">> ", CLREOL·· ' display char prompt
··· DEBUGIN charIn····················· ' get a character
··· IF (charIn = Esc) THEN
····· DEBUG CRSRXY, 0, 6, "># ", CLREOL ' display number prompt
····· DEBUGIN NUM charIn··············· ' accept number, any format
··· ENDIF
··· SEROUT TX, baud, [noparse][[/noparse]charIn]·········· ' send char/num to LCD
··· PAUSE 5
· LOOP
· END
END OF LINE
CODE
'·· Started...
'·· {$STAMP BS2}
'·· {$PBASIC 2.5}
' 06-15-2009:
' the Serial LCD.
' the Serial LCD.
#SELECT $STAMP
· #CASE BS2SX, BS2P
#ENDSELECT
Reset:
Menu:
· DEBUG CLS,
", CR,
······· CR,
· DEBUGIN charIn
··· CASE "1"
····· baud = T2400
··· CASE "2"
····· baud = T9600
··· CASE "3"
····· baud = T19K2
··· CASE ELSE
· ENDSELECT
Main:
· DEBUG CLS,
· DO
··· ENDIF
··· PAUSE 5
· LOOP
· END
END OF LINE
- Stephen
LCD DISPLAY
parallax
www.parallax.com
after a few minutes a pac man starts eating the leters
http://www.parallax.com/Portals/0/Downloads/docs/prod/audiovis/SerialLCD-v2.0.pdf
On page 5 you will find explanation of the DIP switches on the rear side of the display. Your display is probably in TEST-mode!
