High Voltage Switching Regulators
I am looking for switching·regulator devices that can take the mains voltage rectified and step it down to 3.3 volts and 5 volts. The devices with the highest input·voltage I found were 100 volts. Many of these devices look easy to work with. I have a basic understanding of switched mode power supplies. So are there·IC·regulator type·devices that can take·120 volts and step it down without have to use a transformer?
Post Edited (kt88seamp) : 10/16/2009 6:18:46 PM GMT
Depends on the design of the supply. In most cases the transformers provide isolation and step down in one unit to save cost. For multiple output voltage supplies that require isolation, isolation from line noise, and tight regulation there may be an isolation transformer providing an intermediate voltage and a transformer/regulator for each output voltage. This is expensive, so it is not common.
both 3.3 and 5v.
I have 60 of them I recently acquired while converting some cameras for use in a project at work.
They are 330ma units and are meant to charge a lion battery in the cameras...they terminate in a
mini usb plug. I tried using one to power a test board with a prop and some 5v chips and they seem ideal.
I have not cracked one open but they weigh nearly nothing and probably contain a tiny board that could
be mounted in a case easily. 120vac in and 5v dc out and seems to be zero heat generated.
I suppose you could drop the 5v to about 3.3 using diodes in place of a linear regulator but not
sure if this would be good for the prop? Mike Green would probably know....there might be transitory
periods when the prop would get greater than 3.3v doing this?
"Where am I? Where am I going? Why am I in a handbasket?"
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
http://www.electro-tech-online.com/attachments/electronic-projects-design-ideas-reviews/28830d1241249029-relay-noise-resets-microcontroller-5v-power-supply-pi.png
Here is its datasheet:
http://www.es.co.th/Schemetic/PDF/LNK304-306.PDF
