When a Cog runs out of code to run is that like a COGSTOP?
As a newbie I am trying to confirm that if a Cog runs out of code to run does it go into sleep mode and is that the same as a COGSTOP?· Reason I ask because if I call another method with COGNEW will it see this Cog as available or should I always use COGSTOP to shutdown a Cog.· Would the condition be the same if I start a Cog with CONINIT and the Cog runs out of code to run?· Will it be seen as available?
Tony
Tony
Nyamekye,
also, if the cog runs out of code, it'll continue to run, it'll just continue through the cogram executing each location's instruction, unless you have a infinite loop ( here jmp #here ) or cogstop
http://www.propgfx.co.uk/forum/·home of the PropGFX Lite
Composite NTSC sprite driver: Forum
NTSC & PAL driver templates: ObEx Forum
OnePinTVText driver: ObEx Forum
