PCB Connectors
Hey All:
I am looking to resurrect an old project that has two circuit boards that slide into a project case. Interconnections in the past were done with wires and it works but it also introduces a big PITA factor.
When I worked as a field service engineer on VFDs, we had a system that interconnected circuit boards where you would bolt the boards together with stand offs and then slide an interconnecting jumper in between the two boards. It would slide through the top board and snugly plug into the bottom board.
Does anyone know where I could find something like this. The local vendors give me a blank stare and I am sure the part is in Digi-Key but you know how extensive their selection is.
Thanks in advance for your help.
Gerry
Gerry
Through Hole: 10018783-10202TLF
Board Edge: NWE49DHRN-T941
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
www.samtec.com/ftppub/pdf/bcs.pdf
Other places to start looking for board to board mating options:
Molex Board to Board connectors:
www.molex.com/molex/super_family/super_family.jsp?oid=-8809&channel=Products&chanName=superFamily&superFamOID=-8809&pageTitle=Overview
"PCB Connectors" section of Tyco Connector Picture Search:
www.tycoelectronics.com/picturesearch/pictureSearch_PCBconnectors.asp
Standard headers and sockets by Samtec:
www.samtec.com/board_to_board/2006/MB2B_std_hdrs_skts.aspx
Low profile by Samtec:
www.samtec.com/board_to_board/lowprofile_skyscraper.aspx
Andrew Williams
WBA Consulting
WBA-TH1M Sensirion SHT11 Module
Special Olympics Polar Bear Plunge, Mar 20, 2010
