Prop to Prob Communication
krazyideas
Hello.
I am writing a program that uses several propeller chips to do a ton of different things.
I have it working just fine.·My problem is that I am useing as many prop plugs as I am prop chips, so that I can control all the different varubles and functions of my program.·I know there has so·be a way to communicate varubles and information between propellor chips I just have no clue where to start so I can learn how.
What I would like to have is a Master Propellor that would take care of all my varubles and the changes I make to them and then pass those varubles onto my other propellors.
I'm up for learning a new trick, so I could eliminate a bunch of unnessasary wires.
I haven't been playing around with programming long, so relitively simple explanations are much welcomed.
Thanks a ton
Post Edited (krazyideas) : 10/16/2009 4:44:12 AM GMT
Thanks a ton
The Master Propeller could transmit to and receive from any of the Slaves. It could also download new programs to any of the Slaves using Chip's Spin download program (which can be found here: http://forums.parallax.com/showthread.php?p=591445). The 2nd PropPlug could be used for communicating with the slaves from a PC if you wanted with the Master program handling the switching between the Slaves.
Hey, I had heard this was possible but never knew what was involved. That's pretty cool. Thanks for explaining that.
To Krazy,
so this thread can be referenced in the future, could you please give it a more descriptive title? Just click on the pencil icon in the upper right part of the screen and, instead of Where do I start, call it something like Prop to Prop communications or something.
thanks,
Mark
So before I begin to beat on this brick wall, I have one more question to make sure this will do what I want.
When I learn this trick will I be able to use the master chip to modifi a varuble that a slave is useing without stoping or restarting the slave?
As a suggestion, initially forget about trying to download each slave. Use a propplug to load each slaves eeprom. This will make life simpler.
Now all you have to do is communicate with each slave from the master using FDX serial object. If both directions, you need 2 pins on each slave (say P30 & 31 which is also the download pins). On the master, you will need 2 pins per slave. FDX only handles 1 serial device (2 pins) per cog, and of course you will need a controlling cog (initially spin). So this will give you 7 slaves for starters. There are other objects which handle multiple serial ports per cog, but leave this for later if you require it.
This way, you can easily get your project running. Other things can be added later, such as combining pins and a protocol. But for now, keep it simple.
· Home of the MultiBladeProps: TriBlade,·RamBlade, RetroBlade,·TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80) , MoCog (6809)
· Search the Propeller forums·(uses advanced Google search)
I only want to be able to send from the Master to the slaves.
I will take a look at the links you sent me. Thanks a ton.
It is going to be a few days before I can check them out though, This weekend is crazy busy
I did a project that has 4 props all talking serially. 3 props talk to 1 central prop using serial at 115200 baud. No complicated coding is necessary, just copy the necessary memory from one prop to the next, you can pass values through props also, depending on your requirements, chances are 115200 baud passing of values is plenty of speed, even when propagating that data through a central prop.
http://forums.parallax.com/forums/default.aspx?f=21&m=376422&g=377275#m377275
And on the other prop
Pretty easy to do and is fast enough for MY use.
I.E, you would dedicate anywhere from four to 16 I/O lines, and you would send individual bits out on each line (to form a serial data packet).
I really can't remember the exact details, but I believe it was faster than the maximum TTL serial speed of the ATMega168.
Anyway, it seemed interesting. If someone knows anything else about it, please post here.
-Adam
Hey! I'm Adam.
But YOU can call me ziplock.
Blog: braindrink.wordpress.com
"The only problem with the gene pool is that there is no lifeguard." -David Gerrold
Serial tends to use a single or even two wires. And the speed is limited.
The reason people use serial is because they don't want to use up I/O.
Any communication method can be sped up by running more lines of communication.
Serial requires processing power and strict timing.
What your talking about is basically a parallel data bus.
If you just search the forums for communication or similar keywords, you will see many results that talk about many different methods.
http://search.parallax.com/
One thing the prop can do is have four cogs all transmitting serial data out 4 lines. So your data is now transmitting 4 times as fast.
Post Edited (Clock Loop) : 10/18/2009 5:20:00 PM GMT
