How to display pictures which CMUcam1 get on PC?
I have a BS2 & CMUcam1.
How could I open the CMUcamGUI with CMUcam connect to the BS2?
Or I can only open CMUcamGUI with directly connect CMUcam to PC through RS232?
Because I don't know what port the CMUcam connect to PC><
I want to display the picture that CMUcam get on PC!
THX
THX
Again, the Parallax CMUcam for the BoeBot is not designed for use with the CMUcamGUI. If you can build your own interface between the CMUcam and a standard RS232 serial port and change the jumper on the CMUcam for the higher Baud, you should be able to get CMUcamGUI to work. You should be able to use the schematic for the non-Parallax PC adapter board as a model. We can't help you further with this since Parallax doesn't support the standard CMUcam1, only its own version.
The BS2 is neither fast enough nor has enough memory to be able to act as an interface between the CMUcam and a PC for this purpose (relaying an image).
