plz i need help in my bluetooth project
i am an ele & comm engineer
my project is (using the easy bluetooth module to detected a hart beat and show it using labVIEW)
1- have to detect the signal of the module in my DELL laptop.
2-have to see this signal as an output using labVIEW.
3-have to find applications can be used between (labVIEW and easy bluetooth module)
plz any idea inform me
thanx 4 ur help
thanx 4 ur help
http://forums.parallax.com/showthread.php?p=467912
Parallax Engineering
What are you doing to detect the signal for the heart beat? Are you doing this electrically or optically? What circuit are you using? If you don't know, then you need to start doing some internet searches. There are lots of Do-It-Yourself type circuits out there.
We're not going to do this project for you. We will help you if you have specific questions where you show us what you have and what you understand already.
MR MIKE thanx 4 ur help and support, my main concern is to connect the easy bluetooth module to the labVIEW, after that i have 2 think about othr application to the bluetooth
i am already did a research about wat u asked me 2 do, becouse i am still new user 4 the bluetooth and it wasn't in my field 2 study thats y i like 2 have more information about this project..................
i am sorry MR.MIKE i didnt mean i wnt u ppl to do the project i never think like that way sir
do u mind if u offer me maybe another application for it using labVIEW???if u dnt mind
if not than thanx 4 all of ur help....................
thank u all
We can't help you much with the LabView part. That's a product of National Instruments and they would be the ones to provide support for it.
There is an example on the same webpage given above on the use of a Stamp with LabView. The Stamp end of the Bluetooth link would be covered in the documentation and examples given on the Easy Bluetooth Module webpage in Parallax's webstore.
because of i am new in this topic so i want to learn more about it......
is it the module can connect directly to a serial port then the pc???
BLUETOOTH MODULE ~~~SERIAL PORT~~~PC(LABVIEW)
means i do not have to connect any type of circuit before/after the module then to the serial port????
hope you can just inform me if we need or not ????
Microcontroller --wires-- Easy Bluetooth Module ~~~wireless connection~~~ PC (with built-in Bluetooth) and LabView
If your PC doesn't have built-in Bluetooth, you'd have to buy some kind of Bluetooth adapter. Typically these plug into a USB port on the PC. The Bluetooth Adapter would come with the necessary software and instructions.
fixing the easy bluetooth module on a breadboard then from the pins of Tx AND Rx will connect as below
Tx
as a serial port then will goes direct to the PC
Rx
have to detect the heartbeat(the pin need a transmitter outside circuit like any sensors after amplified the signal so its not very important now)
Vdd
power source
Vss
ground
so is this the proper way to create the connection between the the easy bluetooth and the PC ??? thanx for reply....
sorry to keep asking but i am still in the first stage and i want to make sure that my progress can be helpful to the project later on ......................
