LCDAppMod
Hello,
I was looking at some parts that I had bought when I started with the BSII. I found a new 29121 LCD AppMod. My question is if I can modify some prop code or write some to use this appmod with my prop. The connections are easy, but is the appmod just for the BS products?
Curtis
Curtis
in the parallax product description you can read:
"The display uses a 4-bit parallel interface (Hitachi HD44780 compatible)"
here are the objects
Parallel LCD Driver
LCD Driver HD44780 16x2 4 bit 8 bit DEMO
jm_lcd4_ez
you just have to adapt the code to 2x8 characters
for more details download the Hitachi44780 Datasheets (.pdf)
best regards
Stefan
Parallax Engineering
This will give me enough info to start experimenting. You'll are great.
Curtis
