ide interface at 3.3V
Is it possible to communicate with a IDE hard drive using 3.3V signal levels? or do i need to some how shift the voltage up and down to 5v?
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
The IDE standard states that the logic high input voltage must be 2.0V or greater and guarantees 2.4V or greater for high outputs. This would be compatible with either 3.3V or 5V logic. Again, check the datasheet to make sure that the drive itself supports this.
Post Edited (Mike Green) : 10/15/2009 4:23:19 PM GMT
or do i need to use a series resister and clamp diode?
Whenever you (or anyone else) asks a question like this with a "there will be no problems?" part, the only answer you can reasonably get is "I don't know". I have no knowledge or control over what you're actually using or doing. I know that I would check the manufacturer's datasheet to assure myself that the device is supposed to behave the way I expect it to and I might test the device to make sure it behaves like the datasheet says, at least in ways that I feel are critical. If the manufacturer says it's designed to work with 3.3V and 5V controllers, I usually will believe them. If they don't say, I'll look at the detailed specifications, particularly the Vil, Vih and Vol, Voh which define the interface voltages used (and expected).
I will put the series resistors in. Can always populate with 0 ohm if it needs to be faster.
