Battery Power Question
Hello
I have nicad batter here that is a 6 volt and says 1000 mah .. what does the 1000 mah translate into amps. and can i run a oem bs2 demo board from it
Badger
Badger
In the documentation for the OEM board you will see that you can either supply 5 volts to the Vdd pin or 6-24 volts to the Vin pin. A 6v battery should work just fine. 1000 mah means that it will work for a long time before you have to recharge it. A standard 9V battery is only about 100-150 mah, which means it would run out more quickly than the battery you're talking about here.
You may have to pay attention to the total current drain of the BS2 and the devices you have attached to it, but if you've only got one or two things and they're not motors, you should be fine.
thanks again for the dual answer you gave me. I just did not want to blow up my bs2 oem. I have 2 boe boards and one cpu . the cpu has went bad so i only have the bs2 oem and a home work board. that works ok. I also have a hydra that i dont use and another propeller board but i dont have a very good working knowledge of spin .. so if you know any body that would wish to do some trading please let me know.
Badger
The Propeller is a bit intimidating at first, but once you spend a little time with it you'll find that you can do amazing things with it much more easily than you could with a Stamp and PBasic.
Regarding learning the propeller:
I am a propeller newbie (started in June) and it has been a lot easier to learn than I originally thought. Certain things are so much easier than PBASIC that it is sickening. If you have a project in mind that needs the use of objects already available, you can create programs in no time. Here's a thread on my learning experience with figuring out SD card usage. All-in-all it was about 3 hours worth of playing, learning, coding, tweaking, etc. With the my BS2P40/VMusic USB drive datalogger project, it took me about 16 hours total just to get it all to work, and it was still messy (code and hardware).
Andrew Williams
WBA Consulting
WBA-TH1M Sensirion SHT11 Module
Special Olympics Polar Bear Plunge, Mar 20, 2010
(1) 1000 mah is 1000 milli-ampere-hours, and is equal to 1 ah, one ampere-hour. That means it can (theoretically) supply 1 ampere of current for an hour before going dead. But actually you'd be lucky to go 30 minutes at 1 ampere before needing to recharge. Figure 30 minutes at 1 ampere, or an hour at 1/2 ampere, or two hours at 1/4 ampere, and so forth.
(2) While the battery lasts you can run your BS2 card from it, no problem.
· -- Carl, nn5i@arrl.net
I also purchased one of those 9.6 Volt rechargeable battery packs (from the clearance shelf at Wal-Mart).· I mounted the battery on my bot.· I knew that feeding a 5 volt regulator with 9.6 Volts would make the regulator hot.· In fact, I can only get about 60 seconds of use before I have to shut the bot down (the regulator on the protoboard is very hot after 60 seconds and I don't feel safe running it longer).· I am contemplating a small 7.5 volt switching regulator (to drive the 5 volt regulator), or just buying a 7.2 volt rechargeable battery.· Now, I understand that I am probably drawing more current than you (servos, sensors, ect). I am just curious... how hot does your regulator get?· How long do you run before shutting down (when fully charged)?· Did you purchase a switching regulator?· I will probably just buy a 7.2 volt battery (and charger).· Thanks and have a good one.
Bob
Ain't gadetry a wonderful thing?
aka G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
Regarding the mah rating, to get the full mah out of a battery you need to draw it at 1/10C or 1/20C (or whatever rate they used to "rate" the capacity) and of course the cells need to be in good condition. I am happy when I get 80% of the rated capacity out of a pack when discharged at 1C but those cells are designed with high discharge rates in mind.
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
It is·a real coincidence·that you would suggest the 7.2 volt, 2000 mah battery.· I just picked one up last night (and charger) at radio shack.· Yea, I know, I probably got ripped-off, but I don't mind paying a little more for something that I can have now.· Anyway, did you remove one of the cells yourself, or did you buy it with just 5 cells?· With only 5 cells, your total voltage is 6 volts; right? Also, do still charge for 5 hours? Thanks.
Bob
Rich H
