How to power the bs2 oem
Hello
is 9v at 300 mA to the vin and ground to the vss to much voltage and amps for this board to handle for testing and programing.
After that i would want to use a 9 volt battery for this is this ok as well
Badger
Phil
Badger
Phil
From the documentation:
Powering up your OEM-BS2 – There are two ways in which you can power your OEM-BS2:
1) You may apply 6-24VDC to the Vin pin (and ground to the Vss pin)
– OR –
2) You may apply regulated 5VDC to the Vdd pin (and ground to the Vss pin)
Please note that these two methods are mutually exclusive: do one or the
other, but never both!
Thanks so much.. for your time and effort. I hope the rest of the day goes well for you
Badger
Thanks man .. wish i had a brain for all of this ... i can build servers and set up ip networks all day long but this is so much different .. thanks for your patience and your valuable time
Phil
