bs2 not working
Hello
I have a board of education with a bs2px chip .. the 1121a5 chip gets real hot when turned on. have tried it in 2 different boards. does this mean my cpu has gone bad could i replace this chip on the cpu to fix or is it toast. Please if you would give me some insight in to this.. thanks in advance
Badger
Phil
Badger
Phil
i am using a 9v 300 mA wall mount power supply that comes with the hydra board. is this not a good power supply to use.
and by the way i cant get the boe to be reconized by the editor as well
badger
Phil
Hay how are you doing today .. hope all is well ..
hey the chip that is heating up has 4 pins on each sice and is closest to the letters bs2px
badger
Make sure the connection between the PC and Stamp are ok. If you're using a USB BoE, make sure you have the FTDI USB driver installed. The default Windows driver won't work for programming. If you're using some other USB to serial adapter with a serial BoE, it may not be capable of programming a Stamp.
Make sure the BS2px is installed correctly and all of the pins are in the socket.
If you have a voltmeter, measure the voltage between Vdd and Vss. It should be 5V within about 5%.
I had the same issue over the weekend - a "too-warm-to-me" regulator on a BS2. I checked the output from the "9V" wall wart available from the Parallax store and found that it was providing 13V under the load of my project and close to 17V with no load. Obviously it's not a regulated DC power supply.
Later,
DJ
Instead of:
"Those who can, do.· Those who can't, teach." (Shaw)
I prefer:
"Those who know, do.· Those who understand, teach." (Aristotle)
