how to send and number of 90 to Parallax terminal by using the Propstick USB — Parallax Forums
huynh153huynh153 Posts: 3
edited 2009-10-14 19:14 in Propeller 1
Dear all forum members,
I would like to connect the Propstick to Parallax Terminal program and send some data from the Propstick
I do not know where should I start. I begin by modified the code provided, I modified the Program namely "Parallax Serial Terminal" by adding the main PUB as follows:
' CODE
byte rx_buffer[noparse][[/noparse]BUFFER_LENGTH] 'Receive and transmit buffers
byte tx_buffer[noparse][[/noparse]BUFFER_LENGTH]
byte str_buffer[noparse][[/noparse]MAXSTR_LENGTH+1] 'String buffer for numerical strings
PUB main
Start(19200)
repeat
Char(90)
PUB Start(baudrate) : okay
I only add the code of: PUB main consists of Start(19200), repeat Char(90) into the code. The rest of the " Parallax Serial Terminal " are not be changed.
But I could not receive any data in Parallax Terminal. It is my honor to have the suggestion in this issue. I just started to use the Propstick, everything is so new to me.
Many thanks,
Huynh,
    Hello Huynh,
    from what you have posted above I don't understand what you have changed.
    Please provide ALL your code by using the file-archive - project.... function of the propellertool
    which will create a zip-archive with ALL code that is used
    And then use the Post Reply-button and the attachement-manager to upload this zip-archive as an attachement to a posting
    best regards
    Stefan
    Post Edited (StefanL38) : 10/14/2009 7:42:11 PM GMT
