code problem
Hello Forum ,
i have little problem,
I have the connection in the attachment , and this is a part of my code relating to motor enable ( motor start "low" , motor stop"high")
·when i connect the motor enable to the ground the motor·start , but with this connection the motor doesn't start.
it's a problem from the code or from schema ?
Thank you in advance.
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
XMOTOR_ENABLE_N = 3
DAT
org 0
or dira,motorEnablePinN
motorEnablePinN long |< XMOTOR_ENABLE_N
fit 496
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Post Edited (Leon) : 10/13/2009 9:10:47 PM GMT
Why not do it in Spin instead, if all you want to do is test the motor driver?
Thanks in advance.
in SPIN it is the same as making an LED blink. That's all
best regards
Stefan
