PIR field of view
The pir sensor's field of view is too wide for my application. I'm using the sensor to trigger an infrared camera but the sensor fires before the subject is in the field of the camera. The camera is fixed focus and has no zoom. So... can I put tape or someting around the lens of the pir to restrict its view?
John R.
Click here to see my Nomad Build Log
Parallax Engineering
You might want to watch out for reflections taking place inside the tube, though. If the tube is short and the inside of the tube is smooth, the tube might not restrict the field of view as much as you'd expect because light entering at somewhat of an angle (and not head-on) can bounce off the smooth walls. Even if you paint the inside of the tube black, if the paint is smooth and somewhat glossy, reflections can still be a problem. If you want to get fancy, there's something called "flocking paper" that will kill those reflections. Or you can make little baffles, etc. or even rough up the tube walls.
my .2 cents worth.
I also seem to recall that long wavelengths behave a lot differently around obstacles than shorter ones. It's a function of the ration of the wavelength to the obstacle size and shape. I believe that as the ratio of the wavelength to obstacle grows, the obstacle has less effect, but I could have that backwards. I also don’t know if we’re talking about enough of a difference between visible light and IR to make a difference. I’m only mentioning it in case it helps trigger someone else’s thoughts, and/or if things just are not working like it seems they should, maybe this points in a direction to research further.
Given the resources most of us have, trial and error is probably the fastest/easiest way to work this out.
John R.
John R.
Note: Paint does not do anything to reflectivity, just to hide the assembley. And this was done for indoor only. Outdoors, go PVC.
Jim
