ideas on how to build container that measures its contents
Hello,
I'm planning on building a coffee container that will send me a text message (or some other alert) when I need to buy more beans. Then down the line have different types of containers that will communicate with a central server; this will enable me to build a web portal to display a shopping list, or have the list sent to my phone, etc. My expertise is on the software side so I'm hoping to get some ideas on how to go about measuring the amount of coffee beans left in the container. I looked a the flex force sensor; and I don't think it will be sensitive enough for this application; the difference in pressure from full to alert level is probably around 1 lb or less. The Ping sensor may work or the sides of the container may distort the results. Any ideas would be great. Thanks.
The Ping will measure the distance in a container.But I think the Flex Force sensor would fit this app. I believe that the Flex Force sensors can be series together for better resolution. I not positive.
______$WMc%_______
The Truth is out there············___$WMc%___···························· BoogerWoods, FL. USA
- Stephen
