Need photo of wiring from BOE with BS2 to RFID Reader & LCD
Who has a photo of how they successfully connected a BOE with a BS2 to a RFID Reader #28140 and displayed the results ona #27977 LCD. Lastly I want to open a high voltage relay when the RFID tag is read. Has anyone done this and do you have a picture of the wiring? Do you have the program code for this too? Thanks.
2) Parallax provides extensive examples of the use of their products including diagrams showing how to connect them and sample code. Generally this information is provided as links on the product page in their webstore. Look up the RFID reader and LCD in the webstore and follow the links provided. There are other examples in the various Stamps in Class tutorials and in the Nuts and Volts columns. In particular, Nuts and Volts column #6 shows how to control relays with a Stamp.
Start with the "Resources" tab on the main Parallax webpage. When you click on that, you'll get another page with a link to the Nuts and Volts Columns index and a link "Downloads & Press". If you click this latter link, you'll see the downloads page. Click on "Stamps in Class Downloads" to get an index to the various tutorials available from Parallax. "What's a Microcontroller?" is useful as well as the "StampWorks Manual".
Parallax Engineering
Thanks, Bob
Do you have a serial LCD screen? If so, which baud rate is it set to? what I/O pin is it being used on? Can you get the program to run correctly as is using the DEBUG terminal?
Respectfully,
Joshua Donelson
www.parallax.com
I just need that same information to display on the LCD. I have the RX pin of the LCD connected to Pin 12 on the BOE.
I'm seeing if I can get an example of some code that will help you out. Please be patient while I look for the example; I understand you are on a timeline and it is of great urgency, however failed to mention that the “same day timeline” for custom programs is rarely the best approach. In the mean time, have you searched to see if anyone has completed this task by using the search at top of the page?
Thank you for your understanding and patience,
Respectfully,
Joshua Donelson
www.parallax.com
Here is something that displays the label of the tags you provided. This should help get you started with some code that you're using. Please let me know if you do not get the information on the LCD screen; I will be watching the thread.
Respectfully,
Joshua Donelson
www.parallax.com
Don't worry. Be happy
