Advise requested on complex PCB layouts - Can't get it with ExpressPCB
I am working on a new design of 6 RGB LED matrixes interfaced to 3 HT1632C LED drivers (52 pin QFP). Each of the HT1632C chips have 24 cathode outputs (columns) and 16 anode outputs (rows). Basically it will be an expanded version of the SURE Electronics 2416 board: http://www.sureelectronics.net/goods.php?id=142 but this will require 3 chips for red, green and blue.
I started using ExpressPCB (which I have used many times before) with designing the RGB LED matrix displays first and then designing a 52 pin QFP layout to the design specs of each. I then layed out the RGB LED matrixes how I want them and started to connect them in ExpressPCB. I brought all the connections out and then it was time to lay down the 3 HT1632C chips.
The problem is that "each" of the 3 chips has 24+16 connections to the 6 RGB LED matrixes. I can't seem to get it right in the layout to make it work. I am constantly having to add through holes to connect the top / bottom layers and I don't think I will be able to get it layed out right.
My other option is to hand wire it on a perf board - which I may have to do. However, I would really like a PCB layout so I can expand it later and make it bigger. I spent many hours yesterday just with ExpressPCB to see that it may not work for me.
Is there any other PCB software that is free preferably that can automatically draw the PCB if I was to use it's schematic portion first to lay it out in a drawing? I don't beleive ExpressPCB can do this with nodes but not sure.
Any ideas on how to handle this complex mess - or should I just make a perf board with hand wiring (30 guage wire). I have also attached my started ExpressPCB layout too.
Thanks for your help!
don't be afraid to run traces on both sides. you may have to use tighter width/clearance values to get what you need done. how far apart are you trying to keep your traces? can you run them closer together and get it to work?
try using surface mount parts when ever reasonable. don't be afraid of them many are easy to solder and they will make routing easier because they take up no space on the other side of the board.
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
I hate having to go to a perf board if multiple boards "may" be made in the future but I was hoping to hear about an automatic routing solution. I also tried the linking feature in ExpressPCB and ExpressSCH and all it did was highlight which pads needed to be connected. Well that's not hard but somewhat convinient - but it makes you have to create a schematic first also. Ugh.
Other ideas - anyone?
Thanks again.
Searider
Thanks.
Andrew Williams
WBA Consulting
WBA-TH1M Sensirion SHT11 Module
Special Olympics Polar Bear Plunge, Mar 20, 2010
I'm too the point right now that I forgot to add in the 24 * 3 resistors in surface mount (or 1/8W regular) that I will have to redesign the board again to make everything fit OR just hand wire it on a perf board.
Am I really just going about this the wrong way.
Comments...Thoughts?
$110 for 155 sq inch
I pay extra for silver coat and testing. Silver or gold coat is only needed if you want to be rohs compliant.
