Problem with assembly CMP instruction and the CNT — Parallax Forums
DDSDDS Posts: 16
edited 2009-10-11 14:43 in Propeller 1
After spending way too much time debugging my code, I have a problem with this block of code. I have stripped out everything but the code that is causing the problem.
:loop2····· mov······ ST3,cycle·············· ' Calculate time delay, cycle = 1_400_000 but·not important
············· mov······ ST2,cnt
············· add······ ST2,ST3
············· mov······ ST3,cnt················· ' check to see if new CNT is greater than·CNT + 1_400_000.
············ cmp······ ST2,ST3 wc············· ' Is the time up (Set C if ST3 > ST2)
·if_nc····· jmp······ #:loop2················ ' Time is not up
I am adding a constant to the CNT each time through the loop but every 53 seconds it falls out of this loop to the code following it.
The 53-seconds is 2^32 / 80-Mhz clock.
I understand that the C flag is set when the 2nd variable is·greater than the 1st variable in the line (CMP ST2, St3 wc)
It seems that it is getting set once every 2^32 times through the loop - WHY?
Executable code attached.
Thanks for any help
Don
  • JonnyMacJonnyMac Posts: 9,615
    edited 2009-10-11 01:25
    Should you be using a signed compare?
  • DDSDDS Posts: 16
    edited 2009-10-11 01:44
    I don't think so, the CNT is an unsigned integer.
    IF this is correct, then the value I add to the CNT should also be unsigned.
    This would require the unsigned ADD instruction.
    Thanks and let me know if I am wrong.
  • David BDavid B Posts: 593
    edited 2009-10-11 02:08
    If the time isn't up, don't you want to jump back just to the line "mov ST3, cnt? Otherwise you're always resetting your comparison value.
    edited 2009-10-11 02:10
    Say CNT is initially $FFF00000. You add $00100000 to it to get $0000000. By the 2nd reference to CNT, its value is $FFF00008. You're comparing $00000000 to $FFF00008 and C will be true and the JMP will fall through
    edited 2009-10-11 02:44
    Here's the correct way to do this:
            mov     prevcnt,cnt
    :loop   mov     st2,cnt
            sub     st2,prevcnt
            cmp     st2,cycle wc
      if_c  jmp     #:loop
            add     prevcnt,cycle
            ...       'Do cycle stuff.
            jmp     #:loop
    This avoids any problems when cnt rolls over.
    But why not just use waitcnt if you're not doing anything else during the :loop? Here's the code:
            mov     prevcnt,cnt
            add     prevcnt,cycle
    :loop   waitcnt prevcnt,cycle
            ...     'Do cycle stuff
            jmp     #:loop
    It's not only less code, but it gives you 12.5ns resolution with an 80Mhz system clock.
  • DDSDDS Posts: 16
    edited 2009-10-11 13:46
    Mike,
    Thats it. After probably 5-hours of trial & error, you nailed it - Thanks.
    I·kept thinking that when the addition rolled over, so did the CNT but it doesn't for a number of iterations.
    Phil,
    Thanks for the code snippet, this will solve it.
    BTW, the reason I wasn't using the waitcnt instruction is because I am watching a clipped 60-hz signal from a transformer. When I detect a missing cycle, I need to quickly write some variables to EEPROM before the filter capacitor discharges. While I run through this loop, I also watch the state of the input pin so it is a race to see if the 60-Hz cycle finishes or it times out. I have stripped all the other code out so what I posted wasn't long and needlessly confusing.
    I knew that someone on the forum would take a quick look and know see the problem.
    Thanks again,
    Don
    Don,
    One of the tricks about debugging is to manually work through some boundary conditions. That's what I did in your case. You hand simulate on paper the cases just before or just after a rollover or similar change occurs. Often it will either show you the problem or at least drop hints of where else the problem may be.
