Servos move when power on, before program starts
Hi, I am in the process of calibrating my servos to do 90 degree turns precisely. (BOE- BOT Rev C)
I have noticed that both servos turn slightly; close to 10 - 15 deg in opposite directions; as soon as I
switch power on. I would like to know if this is normal or, if not, what is going on?
When I set the Bot down, this servo movement will make it turn slightly to the left (aprox. 5 - 10 deg). This makes
it point away from where I am aiming it to.
Thank you for any light into this situation.
