Power Plug
Spin Studio and many other products seem to use the same power supply plug on there boards. I can't seem to find though in digikey. Anyone know a part number or what category to look under?
also what size is it?
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
The are pretty standard, as long as the same size, 2.1mm
Parallax uses the same size on all their boards too.
Brian
uController.com - home of SpinStudio - the modular Development system for the Propeller
PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
· Home of the MultiBladeProps: TriBlade,·RamBlade, RetroBlade,·TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80) , MoCog (6809)
· Search the Propeller forums·(uses advanced Google search)
found CP-002APJCT-ND which is a surface mount equivalent.
Also, the thru-hole parts come in two flavors: one (CP-202A) requiring large holes or slots; another (CP-102A), small holes. You will notice that Parallax uses the former, even though they seem not to be optimum for PCB mounting, due to the required hole size and the amount of solder required to attach them. The reason is simple: they're much easier to multiple-source than the small-pin variety. Plus, they can probably handle more currentl.
