RS422 problem with bs2
We have a STAMP bs2 application that's been running for several years without problems on a 'older' PC IBM300PL.··We communicate with·the PC via port 1 RS232 to a·RS422 converter.· Then one day we change to a faster PC (Dell 755) & all at once we have communication errors.· Specifically, our message consists of 21 characters, the last is a checksum char.· Our problem is that we're now getting frequent check-sum errors.
Any thoughts?
Here's our command to pull in the message:
SERIN PCdataInPin,NormBaud9600,PCReplyTimeout,DecodePCmsg,[noparse][[/noparse]STR PCmsg\21]
One piece of info: We've found that the problem is much less severe if we go into Device Manager and uncheck the FIFO box in the Advanced properties tab for the PC's RS232 port.
Help!
Any thoughts?
Help!
-dan
Arguing with myself--sometimes me, myself, and I don't always agree.
(Former) Caterpillar product support technician
Did you also purchase a new USB to 232 adapter, or are you using 'native' DB-9 serial ports on the PC?
Some newer PC RS-232 ports put out lower voltage signals -- these may be confusing your 422 adapter.
I should also mention that the PC has no trouble reading replies from the STAMP. Go figure...
Yeah... interesting about the voltage. I'm not sure how to check though. But what I can do is
Any thoughts on why the FIFO UART box seems to make a difference?
