Problem with RS422 — Parallax Forums
Problem with RS422
HjehanHjehan Posts: 5
edited 2009-10-09 16:06 in Propeller 1
We have a STAMP bs2 application that's been running for several years without problems on a 'older' PC IBM300PL.··We communicate with·the PC via port 1 RS232 to a·RS422 converter.· Then one day we change to a faster PC (Dell 755) & all at once we have communication errors.· Specifically, our message consists of 21 characters, the last is a checksum char.· Our problem is that we're now getting frequent check-sum errors.
Any thoughts?
Here's our command to pull in the message:
SERIN PCdataInPin,NormBaud9600,PCReplyTimeout,DecodePCmsg,[noparse][[/noparse]STR PCmsg\21]
One piece of info: We've found that the problem is much less severe if we go into Device Manager and uncheck the FIFO box in the Advanced properties tab for the PC's RS232 port.
Help!
  • JonnyMacJonnyMac Posts: 9,850
    edited 2009-10-09 15:20
    You've posted in the wrong forum. This forum is for the Propeller Chip, not the BASIC Stamp.
  • HjehanHjehan Posts: 5
    edited 2009-10-09 15:40
    Oops.· Sorry - thanks.
  • BigFootBigFoot Posts: 259
    Older PC's had +-12 volt RS232 signals but the newer PC's use +-5 or 6 volt signals. Maybe your RS442 converter does not like the lower voltage signals.
    Russ
