prop and multiple I2C devices best practice?
I need to connect 7 I2C devices to a prop. What is better PCB design practice. Long chain with no branches or a short bus with branches to the i2c devices?
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
Russ
Still, here is my experience: I worked on a project years ago where there were 5 end points on a daisy-chain topology about 10 inches long (I was not the hardware engineer). Like the Propeller outputs, the transition time of the signal was very fast (which is more important AFAIK than the aggregate frequency of the transitions). We had big problems with reflections and tried to save the boards with end of line terminations. Eventually we had to re-spin the board to use a series terminated star topology.
Does the Phillips I2C spec offer any recommendations?
Do what you know Matt [noparse]:)[/noparse]
In the case I described each point on the chain had different reflection characteristics.
The "S" shape of the transitions was the killer ... it was on the main synchronous interface clock.
I have chosen a bus topology for this board. makes routing easier and i am not planning to push the limits of the I2C bus so I don't think it matters much anyways.
thanks for all the information everyone.
