Printing a fixed length decimal number
Is there any routines that print a fixed length signed decimal number.
If so, does the routine take care of the '-' or are positive numbers prefixed with '+' ?
ie.
00000
00005
12345
-0023
Jon
ie.
00000
00005
12345
-0023
Jon
Here's one:
PUB dec(value) | i, x '' Print a decimal number x := value == NEGX 'Check for max negative if value < 0 value := ||(value+x) 'If negative, make positive; adjust for max negative tx("-") 'and output sign i := 1_000_000_000 'Initialize divisor repeat 10 'Loop for 10 digits if value => i tx(value / i + "0" + x*(i == 1)) 'If non-zero digit, output digit; adjust for max negative value //= i 'and digit from value result~~ 'flag non-zero found elseif result or i == 1 tx("0") 'If zero digit (or only digit) output it i /= 10 'Update divisorInstead of "i == 1" in the 3rd from the bottom line, put "i < 100000" to get 5 digits, "i < 1000" to get 3 digits, etc.
Note: This will append the minus sign to a fixed length numeric value (like "-001" or "001"). You will need some additional logic to either add an extra digit position if positive or to put out a "+" if positive.
Post Edited (Mike Green) : 10/6/2009 2:43:39 PM GMT
It took a bit of time to realise what was happening, but I have now modified the routine so a variety of number styles can be printed from the calling routines.
Many thanks
Jon
