help controlling a hacked toy w/ Stamp
So I have a hacked toy cat I'm trying to control w/ my BS2 (I also have a BoE). I've used a Stamp for years to control MIDI devices but this is my first foray into motors and could use some pointers.
What I'm trying to do: There are two motors controlling the cat's motions. I'm mostly new to motors, but unless I'm mistaken they aren't servos (told you I was new to this!)- applying voltage to one pole rotates clockwise, to the other pole, ccw. In order to get this thing to work, I need to rotate slightly one way, then slightly the other (the toy did this with it's original circuit board, and there are stops for the motor but I'm not using the original circuit, just the motors).
Getting the motor to move one way is easy (short pulsout to one pole, other end connected to ground), but how to get it to move back (i.e. reverse the arrangement)?
I'd prefer to use the Stamp alone but if there's a pretty easy cheap solution out there (like a couple cheap ICs or whatever) that's great too. Anybody got any thoughts, suggestions, or hints?
www.me.umn.edu/courses/me2011/robot/technotes/L293/L293.html
Just checked the article, datasheets and even found a schematic and PBasic code for the L293. Perfect, thanks again!
I'll have that cat arching it's back and yowling soon!
Post Edited (chthonik) : 10/6/2009 2:23:18 PM GMT
