BAcking up and beeping, Boe-Bot — Parallax Forums
willrad00willrad00 Posts: 1
edited 2009-10-06 17:32 in Robotics
How do i get my boe-bot to beep while backing up, kind of like a dump truck?
  • dandreaedandreae Posts: 1,375
    edited 2009-10-06 13:48
    You can always add the FREQOUT command to your back up routine.·
    Dave
    Dave Andreae
    Parallax Tech Support·
    edited 2009-10-06 13:57
    It depends on what kind of sound you want. A Stamp can't issue pulses to a servo motor and beep at the same time. You can interleave beeps with the servo pulses (using FREQOUT as a sort of PAUSE), but that might not sound the way you want. In that case, you could add an external processor to handle either the servos (ServoPAL) or the sound generation (SoundPAL). Look these up in Parallax's webstore.
  • PrettybirdPrettybird Posts: 269
    Check out my monster boe bot software in completted projects. I use various sounds for varous moves like right turn left turn and back up. Mabe that will help.
