help me check my code, from keypad to lcd
' {$STAMP BS2}
' {$PBASIC 2.5}
' ========== Program Description ==========
' This program demonstrates using a Hitachi-compatible Parallel LCD Display
' to interface with a 4 x 4 keypad, outputing it to the LCD display
' This code works with the BS2, and is in the language of pbasic.
' ========== I/O Definitions ==========
'RW gnd ' R/W Pin For LCD
E PIN 0 ' Enable Pin For LCD
RS PIN 1 ' LCD Register Select
LDR1 PIN 2
LDR2 PIN 3
TX1 PIN 4
TX2 PIN 5
SEL_KP PIN 6
SEL_LCD PIN 7
KP_IN1 PIN 8
KP_IN2 PIN 9
KP_IN3 PIN 10
KP_IN4 PIN 11
KP_LCD1 PIN 12
KP_LCD2 PIN 13
KP_LCD3 PIN 14
KP_LCD4 PIN 15
' ========== Variables ==========
char VAR Byte ' Character To Send To LCD
inst VAR char ' Induction To Send To LCD
index VAR Word ' Character Pointer
temp VAR Byte ' Temp Variable
cnt VAR Byte
db VAR Bit ' Debounce bit for use by keyScan.
press VAR Bit ' Flag to indicate keypress.
key VAR Nib ' Key number 0-15.
keychar VAR CHAR
row VAR Nib ' Counter used in scanning keys.
cols VAR INC ' Input states of pins P8-P11.
' ========== EEPROM Data ==========
DATA "Mobile Number" ' Message To Send To LCD
' ========== Initialization ==========
Initialize:
OUTS = %0000000000000000 ' Set All Output Low
DIRS = %1111000011110011 ' Set I/O Direction
GOSUB Init_Lcd ' Initialize The LCD Display
' ========== Program Code ==========
Main:
FOR temp = 0 TO 31 ' 32 = 2 x 16 Characters
IF temp = 15 THEN ' Check For End Of Line
GOSUB Next_Line ' Jump To Next Line
ENDIF
READ temp, char ' Read Next Character From EEPROM
GOSUB Send_Text ' Send Character To LCD Display
NEXT
HIGH SEL_LCD 'select LCD
PAUSE 100
LOW SEL_KP
PAUSE 100
LOW SEL_LCD 'select LCD
PAUSE 100
HIGH SEL_KP
PAUSE 100
PAUSE 100
HIGH RS
PAUSE 100
OUTD = %0011 ' Send High Nibble
PULSOUT E,1
PAUSE 10
OUTD = %0011 ' Send Low Nibble
PULSOUT E,1
PAUSE 100
keypad1:
GOSUB keyScan
IF press = 0 THEN keypad1
DEBUG "key pressed = ", HEX key,CR
' LOW SEL_LCD 'select LCD
' PAUSE 100
' LOW RS
' Inst = %00000001 ' Reset The LCD
' GOSUB Send_Inst
'DEBUG "lcd cleared"
'HIGH RS
'keychar=keychar+$30
'keychar.LOWNIB = key
GOSUB Send_Num
PAUSE 50
press = 0
FOR cnt = 1 TO 7
keypad2:
GOSUB keyScan
HIGH SEL_KP
PAUSE 100
IF press = 0 THEN keypad2
DEBUG "key pressed = ",HEX key,CR
'keychar = key+$30
PAUSE 100
HIGH RS
'keychar.HIGHNIB = %0011
GOSUB Send_Num
PAUSE 50
press = 0
NEXT
GOTO Main
END
'========== Subroutines ==========
Init_Lcd:
PAUSE 100
OUTH = %00000001 ' Reset The LCD
PULSOUT E,1
PAUSE 10
OUTH = %00101000 ' Set To 4-bit Operation
PULSOUT E,1
Inst = %00001110 ' Turn On Cursor
GOSUB Send_Inst
Inst = %00000110 ' Set Auto-Increment
GOSUB Send_Inst
Inst = %00000001 ' Clears LCD
GOSUB Send_Inst
PAUSE 100
RETURN
Send_Inst:
PAUSE 100
LOW RS ' Set Instruction Mode
OUTD = Inst.HIGHNIB ' Send High Nibble
PULSOUT E,1
OUTD = Inst.LOWNIB ' Send Low Nibble
PULSOUT E,1
HIGH RS ' Set LCD Back To Text Mode
PAUSE 100
RETURN
Send_Text:
PAUSE 100
OUTD = Char.HIGHNIB ' Send High Nibble
PULSOUT E,1
PAUSE 10
OUTD = char.LOWNIB ' Send Low Nibble
PULSOUT E,1
PAUSE 100
RETURN
Next_Line:
Inst = 128+64 ' Move Cursor To Line 2
GOSUB Send_Inst
RETURN
Send_Num:
PAUSE 100
OUTD = $3 ' Send High Nibble
PULSOUT E,1
PAUSE 10
OUTD = keychar.LOWNIB ' Send Low Nibble
PULSOUT E,1
PAUSE 100
RETURN
keyScan:
LOW SEL_KP
PAUSE 100
FOR row = 12 TO 15 ' Scan rows one at a time.
LOW row ' Output a 0 on current row.
'OUTH = row
'PAUSE 5
key = ~cols ' Get the inverted state of column bits.
key = NCD key ' Convert to bit # + 1 with NCD.
IF key <> 0 THEN
HIGH SEL_KP
PAUSE 100
PAUSE 100
HIGH RS
PAUSE 100
OUTD = %0000 ' Send High Nibble
PULSOUT E,1
PAUSE 10
OUTD = %0000 ' Send Low Nibble
PULSOUT E,1
PAUSE 10
PAUSE 100
LOW SEL_KP
PAUSE 100
IF db = 1 THEN done ' Already responded to this press, so done.
db = 1: press = 1 ' Set debounce and keypress flags.
key = (key-1)+(row*4) ' Add column (0-3) to row x 4 (0,4,8,12).
' Key now contains 0-15, mapped to this arrangement:
' 0 1 2 3
' 4 5 6 7
' 8 9 10 11
' 12 13 14 15
' A lookup table is translates this to match the actual
' markings on the key caps.
LOOKUP key,[noparse][[/noparse]1,2,3,10,4,5,6,11,7,8,9,12,14,0,15,13],key
done:
INPUT row ' Disconnect output on row.
HIGH SEL_KP
PAUSE 100
RETURN
ENDIF
' push ' No high on cols? No key pressed.
NEXT ' Try the next row.
db = 0 ' Reset the debounce bit.
HIGH SEL_KP
PAUSE 100
RETURN ' Return to program.
' push:
' IF db = 1 THEN done ' Already responded to this press, so done.
' db = 1: press = 1 ' Set debounce and keypress flags.
' key = (key-1)+(row*4) ' Add column (0-3) to row x 4 (0,4,8,12).
' 0 1 2 3
' 4 5 6 7
' 8 9 10 11
' 12 13 14 15
' LOOKUP key,[noparse][[/noparse]1,2,3,10,4,5,6,11,7,8,9,12,14,0,15,13],key
' done:
' INPUT row ' Disconnect output on row.
'HIGH SEL_KP
'PAUSE 100
' RETURN ' Return to program.
it cant seems to work ):
im using a SN54LS244J, its attached
pdf
198K
