How do I know when prop is "full"? — Parallax Forums
HughHugh Posts: 362
edited 2009-10-06 17:36 in Propeller 1
This is probably a silly question, but how do I know when I have reached a limit of the Prop?
I've been adding more and more bits of code and the 'F8' compile summary shows there is still free space, but how do I know:
- how many free cogs are in use / available at any one time?
- When there is sufficient 'load' that all cogs are saturated?
Will it just stop working, or will there be some strange manifestations first?
Just curious!
Hugh
Hugh - the thinking woman's Geoffrey Pyke.
  • heaterheater Posts: 3,370
    edited 2009-10-05 07:57
    As you say F8 will tell you how much EEPROM/RAM program space you have consumed.
    Counting used COGs is a bit more difficult. In general the compiler cannot know this. COGs can be started and stopped during run time so the number in in use at any time entirely depends on the nature of the application and the work it is given at any moment.
    Generally most objects, from OBEX for example, will tell you how many COGs they use. In the documentation or in the comments in the code.
    It is up to the programmer to keep track of what COGs he is using as the program progresses. Fortunately in 90% of application COGs are only started once at start up, for device drivers etc, so it's not so hard.
    If you are dynamically starting and stopping COGs in an application it would be wise to check the error returns from the COG starts so as to avoid any "mysterious" failures at run time.
  • HughHugh Posts: 362
    edited 2009-10-05 19:40
    By commenting out bits of OBEX objects that I don't use I have doubled the free space - is this considered 'bad form'?
    edited 2009-10-05 19:44
    The only problem with commenting out bits of library objects that you don't use is that you have to repeat the process if the library object is updated and you want to take advantage of the changes and/or corrections.
  • SciNemoSciNemo Posts: 91
    edited 2009-10-05 20:08
    I comment out the code that I don't need in objects all the time, but always rename the object to reflect the change I have made.
    Not the fish.
    sites.google.com/site/bitwinproject/
  • BradCBradC Posts: 2,601
    edited 2009-10-06 00:53
    Commenting out unused code is certainly a valid option. I used to do it a lot, but it gets messy very quickly.
    PhilPi wrote a pre-processor that analyses and strips out unused code from the intermediate files for compilation and one of the third party SPIN compilers has an option that leaves out all unused parts of SPIN code. It's all the same in the end I guess.
    lt's not particularly silly, is it?
  • jazzedjazzed Posts: 11,803
    edited 2009-10-06 06:06
    Hugh said...
    I've found big programs tend to stop working at run time when there are only 400 or so longs left in the F8 display.
    Your results may vary especially if you have big arrays declared in a method's variables or have undeclared buffers.
  • Ron SutcliffeRon Sutcliffe Posts: 420
    edited 2009-10-06 08:15
    Steve, is that when you are using code compiled with C or with Spin and PASM ?
    I thought is was because C was using a lot of space for the Stack.
    I have found the same thing but only with code compiled under C. I have been using Forth almost exclusively for a few months now, it makes more sense to me but there is little interest in the Forum for some reason. The lastest version of Propforth leaves only 17 unallocated longs. The rest of hub is divid up and have not had it hang on me at all.
  • RaymanRayman Posts: 15,369
    edited 2009-10-06 09:30
    For extra safety, you might want to reserve some stack space by putting something like this in the CON section:
    _stack = 100
    edited 2009-10-06 09:43
    I have found that things stop working when the stack/free reported gets low, less than a hundred longs. I always thought this was odd as everything should be accounted for in the compilation.
    edited 2009-10-06 10:14
    heater said...
    It's very difficult to account for stack usage, particularly in complex programs. I guess its easier with the propeller as you don't have interrupt stacks to worry about, but none the less it's not an easy task to estimate the longest call branch and work back from that to gauge stack usage.
    edited 2009-10-06 10:27
    Yes indeed, determining stack usage ultimately depends on the program and it's flows at run time. So we can't expect the compiler to get it right. Except if we don't have interrupts (luckily the Prop does not) and if we disallow recursive calls. The compiler could then work out the worst case scenario from the call graph.
    But now I think I understand why I'm surprised at the behavior of Spin compilers failing when free space is low.
    When I start up a COG with some Spin code I specify a stack for it to use. It's down to me to figure out how much stack that Spin code may need and reserve that much space for it. I have total visibility and control as I reserve that space myself.
    This is true except for that first Spin code that starts up after reset. In this case I have no say in how big or where the stack is and no visibility of it.
    Edit: Except now I've been reminded of the existence of _STACK so at least I have a say in how big it is even if I don't know where.
    Would it be so hard for a compiler to assume no recursive calls, create a call graph and report the possible worst case stack usage? After all it knows how much stack is required for all the calls, parameters and locals. It could just give up if recursive calls are detected.
    Post Edited (heater) : 10/6/2009 10:33:45 AM GMT
  • whickerwhicker Posts: 749
    edited 2009-10-06 15:22
    heater said...
    True except you do know where it is. It travels down from the top of RAM. And your default say in how big it is, is how little code and data you write.
    I just kind of wish in hindsight the TV and VGA drivers would have declared their buffers formally, instead of just giving an address. Oooh, look at all that free space left-- oh wait, something isn't adding up... I'm sure I'm not the only one.
    edited 2009-10-06 15:39
    Ron Sutcliffe said...
    I only noticed it with Spin/PASM, but I guess it could happen with C. Big LMM/C applications should be ported to Spin [noparse]:)[/noparse]
    edited 2009-10-06 16:04
    whicker said...
    heater said...
    No it doesn't. The stack starts immediately after the allocated variables (end of the VAR section) and expands toward the end of ram ($7FFF).
    _STACK does nothing to set the size of the stack, it simply makes the compiler complain if less than _STACK is available. It's a bit like FIT but for SPIN code. It is just a compiler directive.
    If you start another SPIN cog and give it a stack variable, the interpreter will happily bulldoze its way off the end of that if its too small, trashing any other allocated VAR areas in its path.
    edited 2009-10-06 17:34
    BradC, thanks for the clubbing with the clue bat.
    I see the issue now.
    It's pretty easy to declare the buffer, then just feed the driver the address, BTW. Only real restriction is the buffer for the Parallax drivers needs to be 64 byte aligned.
    Reason being is the tile address also encodes the color as one of 64 palettes, defined in the colors array.
    If that is done, then just use @buffer where the address is given in the driver code.
    Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
    Safety Tip: Life is as good as YOU think it is!
