Error ??? help >>>urgent? — Parallax Forums
harbiharbi Posts: 10
edited 2009-10-07 14:01 in General Discussion
can any body help me with this error .
the code work for some time (15-30)min and this error comes.
826 x 404 - 29K
  • Peter VerkaikPeter Verkaik Posts: 3,956
    edited 2009-10-04 18:13
    Post your program.
    regards peter
  • harbiharbi Posts: 10
    edited 2009-10-06 06:31
    thank u peter
    i found that this error comes from power
    i change Power supp and now OK .
    edited 2009-10-07 09:43
    dear peter
    i need mod function to use like Float32 add(Float32 a,Float32 b ) function in Math32.java
    thankx
    Not sure what you mean.
    Floating point math has no mod function because a divide
    never has an integer remainder.
    Can you give an example of a calculation result that you require?
    regards peter
