ReBOOT issues with the PWMPAL?
Hello All
·I have finally got the time to try out the PWMPAL from Parallax. It works quite well, How ever.
When I power down the board and power it back up the motor does not run with a button press.The DEBUG screen shows an increasing·count value but the motor is not running.
If I down load the program again(to the BS2)·the motor will run with a button press.
The PWMPAL is mounted underneath a BS2 and is on a Pro.Devp.Board.
I have assembled the circuit correctly as its works.
Their seems to be a communication issue when the·STAMP/ PWMPAL reboots?
Any help would be greatly Appreciated.
__Thanks in advance_______________$WMc%_____
The Truth is out there············································ BoogerWoods, FL. USA
Parallax Engineering
I see where Your going with this.And I think You for the input. I'm using the Pro.Dev.Board and not the BOE.
I do however have a faulted pulse generator on My Pro.Dev.Board, I think this could be causing me some trouble.
I'm moving the project over to My son's BOE to see if it works better.
Thanks for the reply
________________________$WMc%________________
I moved the project over to the BOE. And sure enough, I get the same results.I did notice the debug window hooked up by it self when I turned the power back on.I usually have to open the COM port to restart the DEBUG window?
Some what aggravated, I held down the reset button on the BOE for about 30 seconds. I then hit the run button on PIN 8 and the motor ramped up like it should. From this I can carry on with My project.
If You have any insider tricks to deal with this little bug with the PWLPAL. It would greatly be appreciated
___Thanks in advance_______________$WMc%___________
Post Edited ($WMc%) : 10/6/2009 12:51:56 AM GMT
Like you stated in your first reply about the lack of power loss to shut down a program, I seem to be getting power from the serial cable. I unplug the cable, Rebooted the stamp/PWMPAL and the motor started running.
Now that I know whats causing this little BUG I can work around it.
I have been able to duplicate these findings in a test setup to verify this is the problem.
It was Your input that helped me find this BUG.
_________Many Thanks________$WMc%___________
