HW Board not identifiable by BSE but can been seen in a debug window
Several months ago, I purchased a HomeWork board, installed the editor (2.4.2), and did the FirstProgram exercise. After that, I got sidetracked and just recently got back to playing with my HW board.
When I try to identify the board, BSE cannot find the board. However, if I pull up a debug window and press the reset button on the board, the text that I defined in the original program appears. If I try to run a new program, it fails because BSE cannot identify a board to download, even though I know it's there (from the debug interface).
Even though my primary attempts to run a program are on my machine that is using Windows 7, I have also tried it on a machine using XP Pro. I have tried the troubleshooting tips in the manual and have tried everything including tweaking FIFO settings, checking the battery (9.12V, although if the battery was no good I wouldn't get the original text in the debug window)
Not that the code really matters in this case, but here it is anyways:
' What's a Microcontroller - FirstProgram.bs2
' BASIC Stamp sends a message to Debug Terminal
' {$STAMP BS2}
' {$PBASIC 2.5}
DEBUG "Hello, it's me, your little green circuit board!"
END
Thanks for your time
Mick
' {$STAMP BS2}
' {$PBASIC 2.5}
END
Mick
Since the Stamp program works, that implies that the power source is adequate since the Stamp has to be powered to identify or download a new program.
Cheers,
Mick
