EEPROM Programming error — Parallax Forums
VyrusVyrus Posts: 2
edited 2009-10-04 04:40 in Propeller 1
when running the following example code, I get an error message in the Propeller Tool that sais "EEPROM Programming error on com4", however I can load to RAM just fine.· Also when i unplug my serial -> usb adapter, what ever code I'm running stops.
'' Title: SchmartBoard Kit Test
'' Author: Parallax Inc.
CON
  _clkmode = xtal1 + pll16x 'System clock
  _xinfreq = 5_000_000 'set 80 MHz
  Pin = 23 'select I/O pin to test
PUB MAIN
  dira[noparse][[/noparse]Pin]~~ ' Sets Pin as output
  outa[noparse][[/noparse]Pin]~ ' Sets Pin low
  repeat
    !outa[noparse][[/noparse]Pin] ' Toggles Pin
    waitcnt(clkfreq + cnt) ' Wait 1 sec
    edited 2009-10-04 04:04
    There's something wrong with the wiring of your EEPROM on your board (or the EEPROM itself).
    When you unplug your USB to Serial adapter, you're probably causing the Propeller to reset. Since the EEPROM isn't working, the Propeller can't load a program into RAM from EEPROM and the chip halts.
  • VyrusVyrus Posts: 2
    hm... perhaps i should re solder the eeprom and see if that works ... if nothig else i guess i can swap to the stock one (I orderd one of the bigger ones)
