What features would you want?
In a Propeller single board computer, would features would you want? SD/MMC? ADC/DAC? Shift Register? SRAM?
Just curious.
Hey! I'm Adam.
But YOU can call me ziplock.
Blog: braindrink.wordpress.com
"The only problem with the gene pool is that there is no lifeguard." -David Gerrold
Just curious.
Hey! I'm Adam.
I think an open architecture and documented computer would be something I'm interested in because that would be a hobbist's computer.
I think a self contained unit without the need to plug into another computer would be ideal.
I think that if it is going to use SD cards, files and system ROM shouldn't share the same SD card.· It should probably have two external·ports for SD cards.
I think it should have Basic with a math package and a built in machine language monitor.
I wouldn't mind if it was portable and could work with LCD as well as the television.
It should probably have a port for a mini hard drive or hard drives.
I would aim at a computer slightly more advanced than a Commodore 64. I think the C-128 should have had sprites but they existed only in C-64 mode: Color Graphics or Tile Graphics, two or more voices on a chip, probably 16 or more sprites, a low and high resolution screen.
I want something with memory.
It has to do word processing in at least 80 columns.
Something else but I don't know yet. If I aim high, I might just get it.
Post Edited (Chuckz) : 10/3/2009 11:23:19 PM GMT
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
