Please help me out!
Hi Guys,
Its late. I'm tired. Please help me out!
I have a Long named AnsaA, which will have a value between 1 and 60.
I want to draw a chain of hyphens on an LCD screen to represent the value of AnsaA, fifteen hyphens being the maximum. The current code:
doesn't work - I assume due to a property of integer maths that means it wants to draw several hundred hyphens (which is what happens)
Have I missed something?
Post Edited By Moderator (Joshua Donelson (Parallax)) : 10/23/2009 4:55:28 AM GMT
repeat ((AnsaA*15)/60) LCD.str(string("-"))
Right now, you've got your long times 15! That's an awful lot of hyphens. Why not take your long and divide by 10, for example. That would only be 6 hyphens.
Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
Safety Tip: Life is as good as YOU think it is!
Have you tried just a simple division, without the multiply step, and have you verified that the value does, in fact, range 0 to 60?
I'm now wondering whether I have an accidentally nested repeat loop. Time for sleep...!
Hugh - the thinking woman's Geoffrey Pyke.
