Can't find my files??
I am getting started with the Propeller using the Education Kit and the Propeller IDE. I wrote some spin programs and saved them in the PE Kit sub-directory. I wanted to back them up on a USB drive.
So I went into Windows (vista) explorer, went to the sub-directory and the files are not there. I tried cmd.exe and listing all hidden files - nothing there. I was able to open the programs in the IDE and "save as" to the USB drive. I would like to just do a backup through explorer or a sync program.
Where are the files?? How do I get to them??
After a time, all the .spin files on your computer will be displayed. Either your files are there, or they aren't.
If they are not there, you can go to windows explorer, under folder options (or whatever they call it in vista), find and select "show hidden files", and repeat your search.
Good luck!
Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
Safety Tip: Life is as good as YOU think it is!
Jim
Edit: potatohead beat me to it.
Post Edited (hover1) : 10/3/2009 12:53:17 AM GMT
According to the Propeller IDE explorer the files are there - I can open them, change them and save them.
But I can't get to them except through the Propeller IDE
Edit: Didn't know about the invisibility (mis)feature. Urrgh! I have most of my stuff installed in a public area, so no issues there.
Post Edited (kuroneko) : 10/3/2009 1:30:43 AM GMT
Right click on one of the files and select "copy".
Open windows explorer, navigate to your Desktop, and right click and select "paste".
There are permission issues in Vista preventing you from actually seeing the files. Annoying as all get out.
Repeat the above procedure for the remaining files.
While there, or in your user directory, create a new folder. Name it something Propeller related, and cut 'n paste your files there. Next time you run the Propeller tool, navigate to that folder and continue your work there.
Note, while doing this, you never actually open the files with the Propeller tool. You are just using the open dialog as a mini-explorer to cut 'n paste the files.
An alternative is to open the files one by one, then "save as" to a folder where you've got the view permissions needed to work as you normally would.
I dislike Vista.
IMHO, Vista = Windows ME R2
to the right of the ORGANIZE,VIEWS,BURN icons in an icon labled COMPATIBILTY FILES.
I have know idea what that location is ,and haven't found an answer on the Web for it.
So I just copy and move them back to where i want them
BillyS.
Based on this one issue alone I have told my corporate masters that I will not support Vista. I haven't seen a 7 system yet but if it does the same thing I won't support it either. Meanwhile I am getting a test box for seeing how well our stuff runs under Wine under Ubuntu. Even at this point I don't have a single customer who has said "we really want you to make it run under Vista." It's been more like OK, give us a few weeks to run down a XP box. And I don't really see any indication of that changing.
I hate Vista.
Hugh - the thinking woman's Geoffrey Pyke.
