get battery power status
Hello
i have a bs2 board of education and i wante dto know if there is a way to check the battery to see how much power is left. i have the bs2 board wit hthe 9V battery.
i dont see anything that talks about battery managemenet the only thing that is close is
PIN, the new type declaration in PBASIC 2.5 section
The major battery manufacturers all publish curves showing the voltage vs. time at specific discharge rates and you can use that to estimate the remaining battery capacity. Remember that 9V batteries are not designed for high current drains (> 50mA).
681 kohm 470 ohm
Vx ----/ \/\/\---o
/\/\/\----P0 to stamp
unknown |
voltage ===== 0.01 uF film
Vss
What will i need?
1. resistor
2. capacitor What size ?
The resistors can be 1/10W, 1/8W, or 1/4W ratings. One as mentioned is a 681K 1% value and the other is 470 Ohm and could be 10% (or 5%). Lower power ratings make for a smaller capacitor. You could go with a 10% or 5% 680K resistor as a more readily available alternative. You'll just get RCTIME values that may vary more widely than the ones Tracy shows in his discussion.
Post Edited (Mike Green) : 10/2/2009 4:39:29 PM GMT
