Help with 433 MHz RF Receiver and 433 MHz RF Transmitter
Hello
i need help with my RF units i have a totalk lof 3 basic stamp boards they all have the RF T and RF R.
first i need to supply a ID for all my boards exmpale
board 1 = 1A
board 2 = 2B
board 3 = 3C
Next i need to send the id to board· 3C only this will be hooked to a computer and using a vb program to log data in database.
finaly i need ·to send varables to·1A and B2 and·B2 sends to·C3·board
Varable exmpale i have a temp sensor i need to set the temp every hour to all boards.
board 1 = 1A
board 2 = 2B
board 3 = 3C
Don't worry. Be happy
i need to asign a ID to my basic stamp and send it to board 1 and board 2 and board 3 and i need board 2 to send to board 1.
Usually one device has to be designated as the "master". In your case, this might be the Stamp that's attached to a PC. It would transmit to one of the two other Stamps and include a byte in the message that specifies which Stamp is addressed (like "A" or "B"). The "slave" Stamps would normally be listening for a message and would ignore any that they don't recognize and ignore any not addressed to it. The message might contain a value for the "slave" Stamp to use (like a temperature setting) or it might be a request to send back some data (like the current temperature). A slave would always send back a reply when it receives a message for itself. This would let the master know that the slave is operational.
