pogo prop plug
it works very well and is easier to find to.
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
Please use mikronauts _at_ gmail _dot_ com to contact me off-forum, my PM is almost totally full
Morpheus & Mem+dual Prop SBC w/ 512KB kit $119.95, 2MB memory IO board kit $89.95, both kits $189.95
www.mikronauts.com - my site 6.250MHz custom Crystals for running Propellers at 100MHz
Las - Large model assembler for the Propeller Largos - a feature full nano operating system for the Propeller
Maybe you should make one on a small piece of PCB that plugs into the header instead of soldering the pogo pins directly?
Andrew Williams
WBA Consulting
WBA-TH1M Sensirion SHT11 Module
Special Olympics Polar Bear Plunge, Mar 20, 2010
*Edit*
Apparently they are: Pogo Pin
Post Edited (AJM) : 10/2/2009 8:08:15 PM GMT
I have built a test rig with almost 40 of these for testing my propmod-1x1 without headers.
I use jumpers but it presumes the holes are adequate size. I have had a group of RS232 pins wired M-M, M-F & F-F about 6" long. I had them made 20-30 years ago. I just put a little heatshrink on them. They also fit nicely onto pin stakes.
All little gems greatly appreciated.
· Home of the MultiBladeProps: TriBlade,·RamBlade, RetroBlade,·TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80) , MoCog (6809)
· Search the Propeller forums·(uses advanced Google search)
