Easy context-sensitive help for PropTool ? — Parallax Forums
RaymanRayman Posts: 16,460
edited 2009-10-02 20:07 in Propeller 1
Just a suggestion for PropTool creators (because I know they listen sometimes...)
One thing noteably missing is fast help on the keyword that the cursor is currently over when one pushes, e.g., the F1 key...
It would be nice if pressing F1 would bring up the Prop Manual page on that topic...
One way to do this (that I'm thinking of trying myself) is to use some command line parameters when invoking Acrobat reader...
Now, that there's some bookmarks in the Manual, it may be easy to do.
Here's a link with info on how to do it:
http://partners.adobe.com/public/developer/en/acrobat/PDFOpenParameters.pdf
    Hello Rayman,
    good idea !
    I wrote a little script for autohotkey
    that perfoms almost what you want when using the propellertool
    It opens the PDF-manual and does an advanced search for the word the cursor is over
    Click on that entry wich has the word and a lot of dots ................................................................ (in most cases the second entry)
    to jump to the table of contents then click on the line with the blue backround
    F1::
    IfWinActive Propeller Tool
        clipboard =  ; Start off empty to allow ClipWait to detect when the text has arrived.
        send ^{Left}
        send +^{Right}
        Send ^c
        ClipWait 1 ; Wait for the clipboard to contain text.
        send {Left}
        IfWinExist Propeller Manual v1.1.pdf - Adobe Reader
          WinActivate Propeller Manual v1.1.pdf - Adobe Reader ;set focus on PDF-file
          send !{F4}  ;terminate that new search does perfom properly
        Run "C:\Program Files\Adobe\Reader 9.0\Reader\AcroRd32.exe" /A "search=%clipboard%" "C:\Program Files\Parallax Inc\Propeller Tool v1.2.6\Propeller Manual v1.1.pdf"
    return
    here are two other scripts (hotstrings) for easy inserting code /code or urls
    without using this annoying CODE and URL-Buttons of the forum-software that always inserts them at the bottom instead of cursorposition
    you just write "cod" and autohotkey inserts code /code
    :B0:cod::[noparse][[/noparse]code]`r`r[noparse][[/noparse] /code]{up 3}{left 3}{bs 4}{down}
    :B0:url::[noparse][[/noparse] url=] [noparse][[/noparse] /url]{left 13}{bs 4}{right 5}
    for using you have to remove the spaces in "[noparse][[/noparse] /code]" and in "[noparse][[/noparse] url=]"
    best regards
    Stefan
    Post Edited (StefanL38) : 10/2/2009 8:38:45 PM GMT
