driving solid state relays with the BS2
I've struggled to answer this question searching the web - maybe I'm missing something. I am building a controller with a BS2 BOE board and want to fire some 3V SSRs to intutn control line voltage circuits. If the signal inputs on the SSRs have 1K of resistance am I safe to run them directly off the output pins and if not whats a simple way to drive them. I'd like to drive some 2v LEds in parallel as indicators of which SSR is firing but don't want to add to the load on the pins if I'm already pushing the limit.
Having fun but a bit over my head
I had calced the 5ma but didn't trust myself, seemed so low compared to the limit on the pin. I had not factored the issue of combined load so thanks for pointing that out. So I understand, if you had two seperate loads of say 30 ma, would you still be OK if you simply put one on pin 0-7 and the other on 8-15? Not an issue for me now but just wanting to understand. IS there a SIMPLE way to fire higher draw devices that exceed the pin limits without getting into building and involved amplifier circuit?
See Nuts and Volts Column #6 downloadable from Parallax. Go to the main webpage and click on the Resources tab. You'll see a link to the Nuts and Volts Columns index.
