Differential comparison between two accelerometers - Has anyone done this as a
Beau Schwabe
I was talking to a friend of mine in our regular Saturday robotics meeting get together and for a project that he is working on, it dawned on me that if you 'locked' two accelerometers together on the same plane, i.e., at opposite ends of a ruler with the SAME orientation (they wouldn't need to be as far apart as opposite ends, but you get the idea) ... you could normalize any effects due to acceleration, because the sensors would both experience the same forces, thus making acceleration a common mode variable. What you would see if you looked at the differences between the two is the change in angular rate... in a sense a Gyro.
Currently my accelerometer is tied up in something else, and I only have one at the moment, but if someone has done such an experiment I would be very interested in their results.
Beau Schwabe
IC Layout Engineer
Beau Schwabe
IC Layout Engineer
I have the RadioShack //Parallax accelerometer... cant remember the manufacturer and the chip is buried beneath a mountain of stuff. It is a MEMS chip, which depends upon conductivity changes around a little bubble of gas... which changes significantly with temperature as well as with acceleration.
Other than the temperature sensitivity... what a nice little unit!!! I have been trying to get back to it and don't when that will happen...
ANYWAY... if u would place two of these units next to each other in opposite directions... a change in the delta should be the change due to temperature. If you would then feed that value into your calculations from the wings... I can't see how you could be wrong... and it would sell 4 of these units instead of one... which puts this right next to global warming in terms of importance[noparse]:)[/noparse]
Rich
I've wondered the same thing for a couple years now but never had the time to try it. I can see no reason at all why it wouldn't work. I think the physics is sound.
John Abshier
@Phil Pilgrim (PhiPi) - Thanks Phil ... just making sure I didn't hit my head on something in a moment of clarity.
@John Abshier - "...get both acceleration and rotation" - that's what I was sort of going for. My understanding is that you typically take the readings from a Gyro and an Accelerometer both to determine an accurate heading.
Method #1: accelerometer + gyro
Method #2: using 2 accelerometers
So, it seems without adequate testing that there are components of each method that can be derived into similar if not the same results. One using a gyro/accelerometer combo, and the other using two accelerometers. Method #2 might be a little easier to implement, but I'm not sure how accurate one is over the other.
Beau Schwabe
IC Layout Engineer
On the 'Memsic' web-site find the Application Note:
AN-00MX-012.pdf
"Inclination Sensing of Moving Vehicle"
Sorry that I could not link this to you directly but in searching for the link I could not find this application. Maybe you will have better luck. If not I can send you a copy.
cheers, David
www.memsic.com/data/pdfs/an-00mx-012.pdf
The system in the app note uses a single dual axis accelerometer to measure rotation in a single axis, but it appears that if you add four more acceleration axes then you can a total of three rotation axes. In that case then, it shouldn't matter what orientation that the two triple axis accelerometers are mounted relative to one another, since it appears that you could calibrate it out. For convenience though it might be better to align them.
Post Edited (SRLM) : 10/2/2009 11:03:41 PM GMT
If there is rotation, it's more complex.· Consider, for example, the effect of changing the axis of rotation.
If the axis of rotation is not parallel to·a line passing through both accelerometers, then the centripetal accelerations experienced by the two accelerometers will be unequal both in direction and in magnitude.· That may make your world a much messier place.
Sounds like fun.
· -- Carl, nn5i@arrl.net
http://forums.parallax.com/forums/default.aspx?f=25&p=1&m=326074
John Abshier
Post Edited (John Abshier) : 10/4/2009 10:12:30 PM GMT
BTW, ST Micro just came out with some MEMs gyro's back in June I believe... I think the price for a dual axis is something like ~$6. VERY cheap. In fact, I think that's cheaper than two of the accelerometers they make.
Still, an interesting exercise.
Beau Schwabe
IC Layout Engineer
