Need help with a program that reads an input
Hi folks I need some help with a program that reads the status of pin3 and if the pin is high it gosbs to a routine to make the pololu dual micro serial controller go in reverse. And when the pin3 goes low gosub to a routine to make the controller go forward. help
' {$STAMP BS2}
' {$PBASIC 2.5}
INPUT 3
pin3stat VAR Bit
pin3stat = IN3
timer VAR Word
HIGH 0
LOW 2
HIGH 2
PAUSE 100
DO
SEROUT 0,84, [noparse][[/noparse]$80, 0, 6,0]
SEROUT 0,84, [noparse][[/noparse]$80, 0, 0,0]
IF pin3stat = 1 THEN GOSUB mvfwd
ENDIF
IF pin3state = 0 THEN GOSUB mvback
ENDIF
mvfwd:
SEROUT 0,84, [noparse][[/noparse]$80, 0, 6,100]
SEROUT 0,84, [noparse][[/noparse]$80, 0, 0,100]
FOR timer = 0 TO 2000
NEXT
mvback:
SEROUT 0,84, [noparse][[/noparse]$80, 0, 1,100]
SEROUT 0,84, [noparse][[/noparse]$80, 0, 3,100]
NEXT
SEROUT 0,84, [noparse][[/noparse]$80, 0, 1,0]
SEROUT 0,84, [noparse][[/noparse]$80, 0, 3,0]
LOOP
' {$STAMP BS2}
' {$PBASIC 2.5}
INPUT 3
pin3stat VAR Bit
pin3stat = IN3
timer VAR Word
HIGH 0
LOW 2
HIGH 2
PAUSE 100
DO
ENDIF
ENDIF
mvfwd:
NEXT
mvback:
NEXT
LOOP
2) There's one obvious syntax problem. The IF statement has two forms ...
IF <expression> THEN
<statements>
ENDIF
IF <expression> THEN <statement>
You're combining the two and that won't work. Pick one or the other. Consult the Stamp manual or Stamp Editor help files regarding the IF statement for details.
to serial controller. And when the input 3 goes low send this command
thanks
2)
' {$STAMP BS2}
' {$PBASIC 2.5}
DO
IF IN3 = 1 THEN
ELSE
ENDIF
LOOP
